  Thread 21/91
Alumilite Finish Needed
My customer has specified the following finish on a 2024-T6 aluminum U-bolt:"U" BOLTS SHALL BE FINISHED IN ACCORDANCE WITH MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA]A BY A TYPE II NON-DYED OR CLEAR ANODIC OXIDATION TREATMENT. THE ANODIC COATING SHALL BE SEALED WITH A #204 ALUMILITE FINISH.
No problem with the first part, a standard sulfuric acid anodize with a clear finish. But what is and who can supply ALUMILITE? I assume this is some type of lubricant as they are looking for a non-galling film that meets specific torque/tension requirements.
David B [last name deleted for privacy by Editor]
publicly reply to David B
See the responses to Letter Letter No. 14229- your question is quite similar. The old ALCOA Alumilite 204 finish was actually an anodizing specification which called for 30 minutes anodize followed by a hot water seal. The MIL-A 8625A type II is essentially the same, except the seal in the MIL spec is normally a dichromate seal, "unless otherwise specified". Your customer is probably trying to say he wants a true clear anodize, and not a yellow-green finish that the dichromate seal would give. If your customer actually needs to meet the requirements of the MIL spec., there could be another problem, because with 2024 alloy it is very difficult to pass the 336-hour salt spray requirements of the MIL spec without a dichromate seal.
phil johnson
Phil Johnson
- Madison Heights, Michigan
publicly reply to Phil Johnson
David,
Phil has provided you with very detailed information on Alumilite 204 finish. If an alternative finish with the appearance similar to Alumilite 204 is acceptable to your customer, I would like to suggest a Type-II anodic coating followed by nickel acetate sealing. With the latest development in anodizing technology, 0.7 mil coatings produced on 2024-T3 by MLT-II process with Ni acetate sealing are able to pass more than 3,000 hours on neutral salt spray test with respect to ASTM ASTM B117 or MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA]F spec.
Ling
Ling Hao
- Grand Rapids, Michigan
publicly reply to Ling Hao
Dave:
We can help you out if you need clear anodize and a nickel acetate seal or deionized Hot water seal. The answers above are correct about hot water seal and salt spray testing. Feel free to contact myself or Tony at the plant or by E-Mail.
Bob Bramson
B&M Finishers / Prismatic Stainless Steel
Kenilworth, New Jersey
b&m finishers banner
publicly reply to Bob Bramson
Need to know what process "Alumilite 724" is. What is a current equivalent.
Dennis K [last name deleted for privacy by Editor]
industrial products - Erie, Pennsylvania
publicly reply to Dennis K
March 17, 2008
I know nothing about metal finishing but have a question about Alumilite.
Are kitchen utensils (vintage pie plates in particular) safe for food use? I'm wary of buying vintage utensils because what science deemed safe 50 years ago might not be considered safe now.
Any feedback is appreciated.
Ginger Strand
- Dallas, Texas
publicly reply to Ginger Strand
Hi, Ginger. Anodized aluminum is still widely sold today and I see no reason to fear it.
March , 2008
publicly reply to Ted Mooney
