Etching solution for Nickel on PET
I want to etch ~70 Angstroms thick Nickel coating that has been sputtered on Polyethylene. Suggestions are welcome!
Seema Agrawal
- Wilmington, Delaware, USA
What exactly do you mean by 'etch', though? Roughen, reveal grain, remove the whole 70 Angstroms in selected areas? 70 Angstroms is thin enough that I would suspect the latter since you've given us little context to go on.
A mixture of 20 vol hydrogen peroxide with 10% sulfuric acid will do it. However, 70 Angstrom thick nickel is a specialist product, so if you want to etch fancy patterns, try ablation with an excimer laser.
