Scale inhibition of PAPEMP and Poly Phosphonates
1-I am looking for some technical data of water scale inhibition in Dynamic situation for Polyamino polyether methylenephosphonate (PAPEMP)
2-List of chemicals known as Poly Phosphonates used as water additives.
Borzooyeh SUKY
Rosoubgiri Co. - Tehran , Iran
I want the answer of this question.
Damodar Jawalkar
water treatment - Pune, Maharastra, India
Specs of PAPEMP (Jiangsu jianghai chemical):
Appearance : Pale yellow to yellow aqueous solution]
Active content : 32.0%
Phosphorous acid(as PO33-) :4.0%max
PH(1% water solution) :2.0-4.0
Density g/cm3 : 1.24 min
Packing :Normally in 200-250 kgs plastic drums ,IBC can be used as required .
Kelly Lu
Jianghai Chemical - Changzhou, Jiangsu, China
