Aluminum lost wax like process with nickel plating
I am under the impression that there is a lost wax like process which uses aluminum to form the cavity of a mold or custom shape.The aluminum may be produced with intricate detail and later nickel-plated with substantial thickness to support itself. The aluminum is removed in a corrosive bath leaving behind a mold cavity made of nickel with the same intricate detail as the aluminum. Can you please help me find some one that has this capability.
Ray G [surname deleted for privacy by Editor]
- Beverly, MA
Yes, Ray, what you are describing is what the industry calls "nickel electroforming" onto a perishable aluminum mandrel. Many parts are built this way. Please post an RFQ describing exactly what it is that you need and how many, etc..
