Grease causing bleed in black anodized part
I am currently experiencing problems with a aluminium part which is black anodized, we have recently changed the lubricant that we apply during assembly. The issue: there is a black residue coming off with the lubricant, seems to be the anodizing. So far: we have checked whether the anodizing has been sealed and it has. Question Would the lubricant cause the anodizing to bleed.
Justin Budden
- Portsmouth, UK
One possibility- your lubricant may have detergent in it. Detergents are essentially alkaline, and if this is your case, the anodic coating is not bleeding. It is being dissolved.
Dado Macapagal
- Toronto
