  Thread 204/20
Sterling silver causing finger discoloration
I recently purchased a wide band, sterling silver ring that has decorative brass grommets all around it. For some reason, this ring has caused discoloration to my finger. I have worn lots of sterling silver jewerly before, but never had this problem. Why now? Also, how can I make this discoloration go away?
Many thanks for your advice..
Kate W [surname deleted for privacy by Editor]
- Manassas, VA, U.S.A.
publicly reply to Kate W
Sounds like the sterling silver has worn through and you are picking up copper from the brass. Skin secretions are quite acidic and can dissolve metal to form minute amounts of metal salts that deposit on the skin. Some metals, such as nickel can cause allergic responses, excema and even dermatitis.
publicly reply to Trevor Crichton
