How to sharpen knife edge and save time. 316L stainless for knife blade?
Q. I have recently taken on a life-long dream, Knife Building. I have some good clean 316L barstock that was given to me. Does this steel make good blades? If so, I can spend more on the other materials to improve the quality of the rest of my finished piece? How can I tell if it is hardened and tempered? If it is neither, should I try to temper it or send it to someone. Thank you in advance for your help.
Frank Stinton- San Diego, California
A. 316L stainless steel will not make a good blade. It doesn't sharpen well and any edge will quickly dull. To get a good edge you will need a high carbon alloy steel (say 0.7% Carbon). To impart corrosion resistance to the blade you will need to have at least 12% chromium in the steel.
