Electrolytic cleaning of aluminium
Q. I am setting-up a small business repairing motorcycle magnetos and would like to use electrolytic cleaning for the aluminium bodies (I knew a guy who used the process years ago, but he wouldn't tell me about it). Can anyone point me in the right direction, please? I believe the process he used turned the aluminium black by oxidising the surface and this blacking was then removed by some sort of reversal of the process? Trouble is I don't know what solutions are required.
Dave Fisher- Northampton, England
A. Electrolytic cleaning solution for aluminum:
potassium carbonate 100 gm
'water glass'
⇦ this on
Amazon [affil links]
8 gm
1 lit. water, object=cathode (-),stainless steel anode (+),12 V,1-5 A/dm2, 10 - 30 sec.
what do you mean by "Water glass 8 gm" ?
- Algarve, Portugal
April 19, 2011
January 6, 2013
A. Hi Daniel. ⇦ this on eBay or Amazon [affil links] . More detail on letter 15596.
Q. The answer specified a Potassium Carbonate and Sodium Silicate electrolyte. I have used Calcium Carbonate for electrolytic de-rusting of iron and steel.
Is there a chemical reason to use Potassium Carbonate instead of Calcium Carbonate?
- Waukesha Wisconsin USA
August 4, 2016
August 2016
A. Hi Paul.
In general, potassium is much more soluble than sodium which is much more soluble than calcium.
A. Hi Paul
Calcium carbonate is a naturally occurring mineral. It is found as limestone, chalk, marble, etc.
Entire mountain ranges are made of this and they have withstood many thousand years of rain.
It is very close to being completely insoluble so it is not a very promising basis for an electrolytic cleaner.
