Preserving bright copper using benzotriazole solution
Q. I found a Copper Development Association article. In the article is the following:
I am specifically interested in the above process to retard copper corrosion on small exterior copper pieces. I've not been able to find out how to use the agents and if they can be done on a small scale (dip tank) for a craft business. Any suggestions you have would be greatly appreciated.
- PORTLAND Oregon
March 14, 2021
March 2021
A. Hi Dave. Benzotriazole ⇦ this on eBay or Amazon [affil links] is great stuff, and yes you probably can apply it yourself ... but don't expect anything to be a silver bullet against tarnish and corrosion. For stuff that's going to be outdoors I think you are going to need a brass lacquer or some sort of a clear coat, and it's going to have to be periodically renewed every few years. Benzotriazole is a great pretreatment before the lacquer/clearcoat (please read the rest of this thread for info about that), and you can even buy lacquers like Incralac ⇦ this on eBay or Amazon [affil links] or Permalac [adv: Permalac on eBay] which include benzotriazole if you want to do it that way -- but a permanently bright untarnished copper without a clearcoat doesn't sound likely to me except in very benign environments.
I create copper sculptures with a bright finish and would like to preserve the brightness by applying benzotriazole, possibly followed by a clear acrylic lacquer. I think dipping in a benzotriazole solution would be the easiest way to provide thorough coverage for these pieces. Would alcohol (methanol [affil links]?) be the best solvent for this application? What concentration of benzotriazole would give a good level of protection?
Bert Smith- Austin, Texas
I would agree that immersion is a good method of application. Alcohol is a good solvent. Benzotriazole is water soluble at about 2 percent, and is sometimes used as a treatment for recirculating cooling water at low concentrations. It is soluble in alcohol to 50-75 percent, so that would probably be a good solvent for your application. Normally you should get a technical data sheet as well as an MSDS which should give application help.
However, I think a better approach may be to obtain a proprietary and commercial benzotriazole based corrosion inhibitor product rather than to mix benzotriazole with alcohol yourself. The proprietary process might include wetting agents, stabilizers, anti-fume products, a lacquer or varnish, etc., that makes it a usable end-product without the need to reinvent the process sequence.
My husband gave me a beautiful 3-tier water fountain for my birthday. I DO NOT like the look of copper with patina. I like it shiny and new. Is there a finish I can apply to the copper, maybe spray on, that would keep it from getting weathered/patina? How often would I need to reapply the product? Thanks!
Melody
hobbyist - New Glarus, Wisconsin
June 3, 2008
