Auto restoration, restoring original plating
Doing some research on auto restoration and wanted to know if the cad plating on many GM parts can be redone by a home hobbyist. Are there any companies that offer kits? Are there environmental issues involved?
Mike Gardner- Chesapeake, Virginia
Hi Mike. You probably want to switch zinc plating. Times have changed! Cadmium is a toxic, cumulative, metal poison like mercury and lead, and must not be used unless its unique combination of properties is indispensable. Good luck.
