  Thread 200/02
Alkaline zinc plating: parts burning
     The term 'burning' in electroplating refers to the parts getting a coarse, granular look, generally in high current density areas like edges and corners. It occurs when the current is too high for the situation, which causes excessive separation of the water in the plating solution into hydrogen and hydroxide and/or the plated deposit to occur so fat that it cannot form the correct crystal development.
Q. Parts came out from alkaline zinc tank burned at high current density areas, and the burn looks like white powder. The temp. in the tank is 85 deg F and the zinc metal concentration is 1.2 oz/gal and the caustic potash concentration is 20.0 oz/gal. We are using brightener and starter(refine rack). All parts are burning on the rack but the bottom and side parts are burning more. The current density we are plating at is 19 to 26 amps/sq. ft.
popat patel
Popatbhai B. Patel
publicly reply to Popatbhai B. Patel
SUGGESTED ZINC PLATING BOOKS
for Shops, Specifiers & Engineers
zincAlloyPlating_2020
"Electroplating of Zn-Fe, Zn-Co & Zn-Ni" by V Narasimhamurthy (2020)
from eBay, AbeBooks, or Amazon
zincPlatingMuralidhara2016
"Zinc Electroplating" by Muralidhara & Venkatesh (2018)
"Alkaline non-cyanide zinc plating with reuse of recovered chemicals" by Jacqueline M. Peden (1994)
from (U.S. EPA)
../abwd/zincPlatingGeduld1990
"Zinc Plating" by Herb Geduld (1990)
tin_zinc_alloy
"Tin-Zinc Alloy Plating" by Tin-Zinc Alloy Plating (1952)
from eBay, or AbeBooks
zinc_cyanide_plating
"Zinc Cyanide Plating Solutions" by William Blum (1921 Classic Reprint)
zinc_plating_classic
"The Composition and Comparison of Zinc Electroplating Solutions" by John Elder Pyron (1917 Classic Reprint)
A. Dear Mr PP,
You need to up the Metal conc. to 2 oz/gal and also ensure that the NaOH does not exceed what you currently have. Maintain a metal:OH ratio of 1:10 and you will regain control.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
publicly reply to Khozem Vahaanwala
thumbs up sign Thanks very much for the knowledgable and confident response, KV.
publicly reply to Ted Mooney
