Brass finishes
i need to match two components in color/finish, one is made of brass the other of aluminum, my problem is that I can anodize the aluminum anyone of several different colors but the problem is that I can't seem to find a way to have the brass any other way than brass, nickel plated both bright silver or dull black. Is there any other way? if not how do I preserve the bright brass finish for 2 years in an inside environment?
thank you for your help
- clearwater fl
Dear Aldo ,
Have you thought of Gold Anodize the Aluminium , and Gold plating the Brass part after Bright Nickel plating , many shops will be able to match the colors for you of if you want to do it yourself contact
Technic who will be only too willing to help
Best Regards
John Tenison - Woods
- Victoria Australia
We have had good success painting both brass and aluminum components. Perhaps a paint process for both would allow the best match possible.
Michel Moninger- Sarasota, Florida
Hello I'm responding to your website concerning the matter of brass-plating. I'm in the process of plating chess figures, made of lead, could you recommend a suitable solution mix, as I, M finding control of colour difficult. I would also like a recommendation for tank control ie.. material and size.. Thank you
Nigel Hutton- San Jose
