Galvanizing kettle
Selection of galvanizing kettle material
Pathak s h
- Vadodara, Gujarat, India
What material are you presently using and what do you like and dislike about it, Mr. Pathak? Please spend more time on your question than you are asking a stranger to spend on the answer for you -- our readers are usually unresponsive to flash card quizzes :-)
Dear sir,
I wanted to know, a special material is used for manufacturing of zinc tank which holds the molten Zinc in hot dip galvanization process. the type of material used and also its chemical and mechanical properties may be intimated. The advantages of using the material also may be intimated.
Jayaram Chetty.
Galvanization - Chennai, Tamilnadu, India
