Can I accelerate the rusting process?
I am Youth Pastor and I have a company cutting me some letters our of steel for a logo backdrop. I need to find the fastest way to make these uncoated (except for the oil coating) letters to rust severely. The letters are on 14 gauge steel and are cut with a laser (no rough edges). I would like to know what chemicals (or preparations) are necessary and how long it will take to rust the entire facing surface.
Jeremy Brown
- Bryan, Ohio
The things youth leaders are expected to do. First, scrub them with soap and water, then run them thru a dishwasher cycle. Take them outside on a wood or similar rack to make them easy to get to and out of the dirt. MIST them with a spray bottle with 4-6 teaspoons of table salt and one oz of plain vinegar in bulk on eBay or Amazon [affil links] (per quart). Do this in the AM and The pm. They will start rusting in a day or two and get deeper and darker each additional day. Dry them in the bright sun for a day or two and coat with clear lacquer or polyurethane. Both will yellow but the darkness of the rust will hide most of it.
If they are uncoated, putting them outside in our Ohio weather will do the trick. Otherwise, soak them in 5% salt Solution.
Cynthia L. Meade
- Sylvania, Ohio, USA
In one of my past movies I had to do such a thing all I did was spray urine onto the things needed to be rusted. this worked within a day or to of being soaked in urine.
Jeffery Rush
- New York, USA
