Melting point and conductivity
Hi how ya'll doin,
I need the melting point and conductivity of...410 ferritic stainless steel alloy wire, l-605 cobalt-chromium alloy wire, alloyx nickel chromium alloy wire, titanium alloy wire, 4043 aluminum alloy wire, copper- nickel weld metal, "mild "steel" (copper coated iron based alloy) wire, magnetic wire, nickel-chromium alloy wire, bare copper wire, and nickel chromium wire.
If you could give me this information or suggestions on where to find it I would be much obliged...
Kelsey- Friendswood, Texas
Kelsey,
I do not have an answer for your question(s) but I could suggest some leads. Also, when you call an alloy without a number, the compositions can vary for the same alloy name, e.g. Ni-Cr alloy can have various % contents of Ni and Cr.
If these are wires used in certain applications, say electrical, you may go to some place like Radio Shack and find available data/specs and/or find the name of manufacturer and call their customer service. Also, you may check Thomas Register for manufacturers of such items.
Mandar Sunthankar- Fort Collins, Colorado
