PROBLEMS FACED IN CHLORIDE ZINC PLATING
I am a electroplating chemist and handling a chloride zinc plating line, plating automotive components of castings and sheet metals. I am facing a problem of "discoloration of green passivation" after 2 or 3 days of plating. I've thoroughly given carbon, zinc dust this on eBay or Amazon [affil links] treatment for any organic/inorganic impurities. Now the solution is perfectly alright in Hull cell test. The discoloration is coming only in green passivation and not in blue or yellow. I am following strictly the parameters recommended by the supplier of the passivations. Can any one help me in diagnosing this problem.
Thanks in advance,
Rummy Cai
- Chennai, India
Dear Rummy Cai,
The problem isn't as rummy as it sounds :). You need to start with yr plating bath. Reduce the addition of R Brightener to minimum levels and increase dosage of M to ensure total dissolution of the R in the bath. After that please rinse copiously to ensure that no brightener film remains on the part before passivation. I do hope you have a strong Nitric dip prior to Green ?
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
