Alodine outgassing
I am experiencing contamination on an optical surface when an aluminum part which has been given an Alodine coating. The sample was initially baked out at 100 °C & the "outgassing" was experienced at 70C. Is there a spec for this? Is anodizing better?
Mike Hogan
- Lexington, Massachusetts
70 °C is 158 °F which is too hot for bare aluminum chromate. The MIL Spec says not to bake any coatings over 140F. The gel breaks down when the water cooks off.
robert probert
probertbanner
Mike, Alodine or Iridite or Chem Film or ? are a chemical conversion coating. They form a very thin "gel" on the surface. 24 hour later, most of the water has evaporated, but not the water of hydration. You will see this in chemical formulas as a .H20 When you dry the part above 40 to 45C, you drive off the hydration and the gel literally turns to a non-adherent powder. So, do not bake. Yes, anodize is superior to chem film in nearly every aspect, but it costs more.
Please check treatment temperature requirement for this surface finish. I think the max rinse temp or blow air temp is 140 deg F which is lower than 100 °C.
Dado Macapagal
- Toronto, Ont
