Silver plated directly over steel
I am looking for a process to silver plate low carbon steel wire without any substrate. Another metal over the steel will interfere with the use of this product. Is there a way to activate the steel to plate silver directly over it?
David Murphy
- Charlotte, North Carolina
First get all the chlorides out of your water. Then run the wire thru 5 %/vol 66 Be Electronic Grade Sulfuric Acid, then make the wire cathodic in a solution of 6 oz/gal Potassium Cyanide in deI or distilled water, then without rinsing go straight into a weak silver strike, continue without rinsing into the heavy silver build-up. Be aware that most commercial silver brighteners are antimony or selenium and this interferes with RF, then if RF (Radio Frequency) is a consideration use a silver brightener that is carbon disulfide.
robert probert
probertbanner
