Corrosion in salt-making
Hello,
I have a problem. I have a container where I make salt and there is a lot of corrosion. The container is made of SS316 L, and in it I have saturated Salt with a pH=6 and a temperature for about 100 C. What material do you recommend me to use instead.
Peter Rask
- Kjellerup, Denmark
I think titanium construction would be okay, but there are a number of things the container could be coated or plated with.
Pyrex glass. Only the VERY high priced SS will work in your conditions. 316 L is good, but not good enough.
Peter,
May I suggest that you use an appropriate plastic.... but why 100 °C?
I used to design brine makers for the salt (mining) industry and used Polyethylene but Pe is nbg at over, say, 150 °F.
At 90 °C, a dual laminate tank made out CPVC is OK ... PVDF is OK to 140 °CC and the other weldable fluorocarbons such as Tefzel, ECTMP (i.e., Halar) are supposed to be good to around 200 °C ... however, they cost an arm and a leg hence the fibreglassing to the thinner thermoplastic to give structural strength.
freeman newton portrait
Freeman Newton [deceased]
