Coating / Plating exposed to Freon
Can anyone recommend a coating / plating for steel in a freon environment? The parts must withstand 5000 hours in freon at -40 F. Application: Hydrogen fuel cells.
Jack Arnolde
- Chicago, Illinois, USA
I would expect electroless nickel to be fine.
I would think that copper would be the way to go, since air conditioning systems are made with copper piping. Copper is also a very good heat dispersing material.
Dan Brewer
chemical process supplier - Gurnee, Illinois
