Plate nickel into porous Si
I am trying to plate nickel into porous Si which is 250um deep. How can I check whether plating solution indeed reach the bottom of pores?
Randy XU
- Los Angeles, California, USA
I don't think that's quite the correct question, Randy. I think the correct question is whether metallic nickel was deposited there. Depending on the details of the pores, I think x-ray fluorescence can probably by focused below the surface.
