Plated vs. Clad Materials
Q. Could someone explain/refer me to information regarding the differences of plating vs. clad materials.
Rich Peyton
- USA
A. Hi Rich. In general, and the way I've heard it, a 'clad' item has had a skin of another material mechanically bonded onto it whereas a 'plated' item has had the skin electrochemically deposited. But people use words as they wish, which can lead to confusion.
The practical difference is that a cladding would generally be significantly thicker than a plating. Another difference would be that some materials are easy to plate or easy to plate onto, others are harder. And the same thing with cladding. If you wanted to put a stainless steel 'skin' onto an aluminum part, you would probably use cladding technology; if you wanted a nickel-chrome skin, you would probably electroplate it.
Q. What is the Electroless Nickel process for Clad material-Stainless steel & aluminium ?
Thanks for your time.
Huat
- Bangkok, Thailand
A. Sorry, Huat, but I can't understand the question. Please post your situation, rather than an abstract question, and we may be able to help you. Thanks!
