Removing Lacquer Finish from Brass Hardware
Q. I am trying to remove the clear lacquer finish from new exterior door hardware for 5 sets of Marvin doors. I tried applying Klean Strip for 15 to 30 minutes, per manufacturers directions, but no success. Any suggestions?
Richard Halloran- Bala Cynwyd, Pennsylvania, USA
A. Richard,
A lacquer finish needs a lacquer type SOLVENT ... and your Clean Strip, which I'm not familiar with, might well remove lower grade finishes such as enamel and latex.
So go and get some aromatic hydrocarbons or some polar solvents such as acetone
[affil link] Flammable!
... and try that.
But why in the hell are you trying to remove that finish? If you succeed, you'll have to polish it and polish it until the base metal eventually appears. Yuck.
Freeman Newton [deceased]
Q. I am new to clock repair and have been attempting to find an easy way remove the factory applied lacquer finish to the brass on anniversary clocks. I have tried soaking the parts in acetone, coating with paint stripper with no results. I know that buffing with a good compound with work, but very time consuming and generates a lot of heat. As a point of interest for final finish and protection after buffing I use a product called Flitz ⇦[this on eBay or Amazon affil links] ..absolutely amazing. Any suggestions would be greatly appreciated...Thanks...Paul A.
Paul Arsenaulthobbyist in clock repair - Glen Brunie, Maryland, USA
A. Although you are calling it lacquer -- perhaps for lack of a better word -- it's not lacquer if lacquer thinner ⇦ on eBay or Amazon [affil link] Flammable! doesn't remove it. Methylene chloride based "Aircraft Stripper" should remove just about whatever it is, but it's very nasty stuff!
Q. Thanks for the info. If my memory serves me correctly, while working at Pratt Whitney aircraft back in the 60's we used a product to degrease parts that was heated in huge subfloor vats and smelled like acetone. Is this the chemical you are referring to? Thanks..Paul A.
Paul Arsenault- Glen Burnie, Maryland, USA
A. Hi again. I probably shouldn't try to guess what chemical Pratt & Whitney used to degrease parts, so I added an Amazon link for the aircraft stripper which you can study further if you wish. Good luck
