Metal identification
Is there an easy way to tell the difference between silver and aluminum. If there is what is it. I looking at recycling for the wireless industries.
Johnny Fraley
- Plano, Texas
Dear Mr Fraley,
Assuming you only have aluminium or silver, you can tell the difference by immersing the part in warm is 50% nitric acid. If there is a reaction and the surface is attacked it is silver, if nothing happens it is aluminium.
Kind regards,
Sjamp van Esch
Sjamp van Esch
- Eindhoven, The Netherlands
Nitric Acid attacks silver. Nitric Acid does not attack Aluminum.
robert probert
probertbanner
First of three simultaneous responses --
Nitric acid is hazardous and I wouldn't suggest it if there's a suitable alternative. I'm more of a kitchen chemist and "Draino" comes to mind. Straight caustic will dissolve the aluminum and leave the silver behind (might be a little gray or blackened, but basically intact).
milt stevenson jr.
Milt Stevenson, Jr.
Plating shop technical manager - Syracuse, New York
Second of three simultaneous responses --
You received good advice about nitric acid testing. But also note that silver weighs more than three times as much as aluminum, so a small amount of experience may help you immediately judge which one you are dealing with.
Third of three simultaneous responses --
Nitric is OK but highly obnoxious, dangerous and toxic. You can alternatively use muriatic (30% hydrochloric) acid or a solution of 20% caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] dissolved in tap water. Both will attack aluminum very fast but not silver.
Guillermo Marrufo
Monterrey, NL, Mexico
