Iridite Class 3 vs. Alodine 1200S
Q. I have had a request from a supplier. The supplier has ask, "if they can substitute an Alodine 1200S finish for a Iridite Class 3 'Clear or Yellow', finish that we call out?". My question is are they the same? We use the Iridite as a corrosion preventative film for electric and electronic applications, for low resistance contacts. I cannot find anything on Alodine 1200S, can you help?
Thank You for your help!
Shawn Perkins
- Wichita, Kansas
A. Alodine is a trademark of Henkel North America, Iridite is a trademark of Macdermid. They both refer to MIL-C-5541 approved conversion coatings, but as you can infer from the "1200", there are a number of formulations, tailored to certain operating conditions and you would need to read the data sheets from these manufacturers to see if the application procedure and operating conditions are the same.
A. Iridite is a brand name of Macdermid, with several versions such as Iridite 14-2. Alodine 1200S is a brand from Henkel Technologies. Both products are on the Qualified Products List for both Class 1A & 3 coatings. You can download QPL-81706 [⇦ this spec on DLA] from the DoD's ASSIST site: http://assist.daps.dla.mil/quicksearch/^https://quicksearch.dla.mil/ Since you seem to be using Iridite® in the generic sense, it is more important to specify MIL-C-5541E, Class 3 than the brand name. Also, each of these products yields a slightly yellow Class 3 coating. If you need Class 3, Clear, there are products specially formulated as such from these and other companies.
Ken Vlach [deceased]
- Goleta, California
A. Iridite is a trade name for a whole family of chromate conversion coatings. Alodine 1200S is the trade name for aluminum chromate that meets MIL-C-5541. Iridite 14-2 is the particular trade name for a product that is chromate conversion for aluminum. Assuming you probably mean Iridite 14-2, yes Iridite 14-2 and Alodine 1200 S both apply Class 1 or 3 on MIL-C-5541.
robert probert
probertbanner
A. For low resistance electrical contacts you should use Alodine 600
Paul pelletier
- meriden Connecticut
June 24, 2008
Need Lower Electrical Resistance from Chromating
Q. We are using Alodine 1200S for conductive chromotisation on aluminium components. We require a lower electrical resistance. But after Chromotisation we are getting higher resistance value. We require Class 3 coating as per MIL standard. Please suggest.
KATARU EDUKONDALU
BHARAT DYNAMICS LTD - HYDERABAD
October 16, 2015
