Large Copper Sheeting - where to buy
Hi Everyone,
I wanted to cover a 5ft x 5 ft piece of plywood with copper sheeting. Does anyone know where I can purchase copper sheeting this big ? I don't mind if I get some sheeting 1 ft x 5.5 ft - then I can buy several of those, but I would like each of them to at least completely run along one of the sides. Preferably 36 gauge or thereabouts.
- SJ, California, USA
Try your local roofing material supplier, quite often they will stock copper sheets 36"x120" for use in fabricating copper roofing items; gutters, eave drip etc.. The most common size/weight is 16 oz. copper and this should be adequate for the usage you describe.
T.Moss- Titusville, FL, U.S.A
