Coating to seal water leaks on fire truck
We have a 3000 gallon stainless steel tank mounted on a mack truck that we haul water for fire suppression for a volunteer fire dept. We have a few leaks in the bottom of the tank. I need to know if there is any kind of coating that we could brush on or roll on the inside of the tank to stop the leaks. It would have to be something that would not come off because it would damage the pump on the pumper truck.
Timothy W. Horton
- Pontotoc, MS, U.S.A.
Our volunteer fire department just purchased a used tank and it needs a sealer applied inside the tank. Do you have any ideas on what kind and where to purchase the sealer?
K. Horn
Cartwright Volunteer Fire Dept. - Oklahoma
