Gaseous vs. Salt Bath Nitrocarburizing
Q. Is there a significant difference between salt bath nitrocarburizing and gaseous nitrocarburizing in terms of the resulting finish, both in abrasion and corrosion resistance?
Thank You.
Benge Ambrogi
R&D - Manchester, New Hampshire
Q. I also work in accessory technique and I would like to receive information on salt bath nitrocarburizing versus gaseous nitrocarburizing.
Best Regards
Emanoel Ribeiro de Almeida
Sorocaba - SP - Brazil
A. Greetings, Benge and Emanoel Ribeiro de Almeida: Suggest you see ASM Metals Handbook Vol. 4 'Heat Treating'[this on Amazon affil links]. There are numerous end-notes at the end of the chapters.
Also, you should contact, Mr. Dale Poteet, the godfather of nitrocarburizing or Kolene. Good Luck Gentlemen, Sam.
Sam Massey
- Waco, Texas.
Q. Hello, my name is mahdi mirjani. I am a MS student of metallurgical engineering. I am working about gaseous nitrocarburizing of low carbon steel (for example C60 and CK15). Please send for me most information. THANK YOU.
mahdi mirjani
isfahan university of technology - esfahan,iran
A. Hi, I am now working about "the reasons of crack formation during gaseous nitrocarburizing". What do you need exactly?
Sincerely yours.
mahmood noroozi
amir kabir university - tehran, iran
