Polishing flat bronze pins
We are making flat pins in bronze approx. 1" square. We are seeking a method to bring the flat surface to a mirror finish. We will try anything.
Help Please!
Lance Johnson- OHIO
If your parts are flat, I suggest you use a treated dry organic media compound only. Normally dry organic materials are used in 2 parts; however, separation maybe a problem. Stay away from wet systems.
AF Kenton
