Titanium scratch marks on porcelain
Q. I recently bought a titanium watch and now have discovered that it is the culprit that is marking my bathroom sink with small black 'scratches' which I cannot get off. I would like to know what does this and how I can clean up my sink.
Colin U [last name deleted for privacy by Editor]
- Oxford, UK
similarly
Q. Hi Colin, Just wondering if you ever found a solution to removing those titanium marks. I have the same problem. Purchased a titanium watch for my husband a year ago and now both of our sinks have those black marks.
I tried Lime-A-Way this on eBay or Amazon [affil links] (suggested at another site to remove marks left by metal) but it didn't do a thing. I have also tried baking soda and a 3m green scrubby to no avail. I'm surprised I haven't removed the glaze from the porcelain!
Please tell me if you have discovered a way to remove them. Thanks,
Emma B [last name deleted for privacy by Editor]
- Calgary, Alberta, Canada
Q. How can I find the answer to removing Titanium scratching on porcelain. It's a brand new white porcelain sink and pot marks have left these same little scratches as described in this other letter. Thanks.
Susan D [last name deleted for privacy by Editor]
- Philadelphia, Pennsylvania
Q. I, too am having the problem with my pots and pans leaving grey "scratches" on my new porcelain sink. I have been told that the sink will need to be "re-glazed", which I looked into and is very expensive and done by a professional. If anyone has an easier solution, please tell me!
Lisa F [last name deleted for privacy by Editor]
- Seattle, Washington
A. I tried 400 grit sandpaper and it worked very well. It doesn't seem to damage the surface, but you might want to test a small area first.
Tina M [last name deleted for privacy by Editor]
- Pittsburgh, Pennsylvania
A. The best way to remove the black scratches and marks from porcelain sinks is with Soft Scrub [affil links] liquid cleanser. Apply to a damp sponge and buff away all the marks!
M. Herman
- Potomac, Maryland
A. Barkeepers Friend this on eBay or Amazon [affil links] does a fantastic job of removing gray metal marks from white porcelain sinks. Also, I use Soft Scrub with bleach [affil links] to remove other stains and rust marks. Good luck!
René B [last name deleted for privacy by Editor]
- Georgetown, Texas
Q. I've been using bleach with chlorine, which definitely takes out the black scratches but it lessens the glaze and you end up having to use it almost daily. I didn't find ANYTHING else that worked!
Catherine B [last name deleted for privacy by Editor]
- Duncan, B.C., Canada
A. I've solved the titanium scratches on porcelain problem! And it was so easy!
Get a bit of plumber's rubber - it looks just like a pencil rubber (or eraser if you prefer) - and rub the scratch with it, then clean off with soap and water and buff with a soft cloth. Job done, minimal elbow grease (I found it even easier with a bit of water on the rubber), maximum results!
The rubber should be available from any plumber's merchants, but if not try getting in touch with a company that actually makes (or even fits) porcelain sinks. That's how I got my bit - from a sink manufacturer.
I now have a sink that looks as good as new and have promised my wife that my titanium wedding ring will never go near it again! Good luck all.
Greg [last name deleted for privacy by Editor]
- Nottingham, UK
Thanks, Greg, but we can't find a reference to plumber's rubber anywhere on the net, and have never heard of anything like it. Could you be referring to a pumice stick this on eBay or Amazon [affil links] ?
Ed. note: it is reported by a reader further down, that a pumice stick scratched a black toilet bowl, so it may not be a good answer for other than white bowls.
A. With regards to Titanium jewelry / watch marks deposited on porcelain surfaces, I can confirm that a Plumbers tool, known as 'China rubber', which resembles a normal stationary rubber works fantastic- I removed a 10-15 cm mark within five minutes using a bit of elbow grease. I found that it worked best without using any water. I could find no trace of of any damage left by the cleaning process. This can be sourced at any plumbing merchants, but it is not cheap- £18 for a small piece, but a worthy purchase in case of further marks! (Got mine from local Plumb Centre branch)
Jim O [last name deleted for privacy by Editor]
- Desborough, Northamptonshire, England
A. I too have used a "plumbers Rubber" except in the UK it is known as China/Bath Rubber. It is available from any reputable plumbers merchant..
It worked like magic, just like using an eraser on a pencil drawing. I too will never let my Titanium ring near the sink again... Should have looked here before spending several grueling hours with all manner of cleaning products.
Thanks All
Shaun
- London England
January 28, 2008
thumbs up signThanks for all your help with this. I have been trying to find a product that removes my husband's titanium wedding marks from our ceramic sink also. I've found that the 'china rubber' is also known as Cramer Bath Rubber, and I found it at Screwfix for £7.49.
Kellie Bradley
- Manchester, England
March 22, 2008
A. I found what I think the Brits are talking about: at diybathrepair.com/html/stain_eraser.html
I have phoned the US contact and am awaiting a return call on where these can be purchased in the US. I will post it up here for the non-Brits on the site.
Steven L [last name deleted for privacy by Editor]
- Oak Ridge, North Carolina
Q. I haven't had much luck with the Rubber idea... I've only tried Trojan, though -- should I switch to Durex or Lifestyles?
Bob Party
- Portland, Oregon
June 3, 2008
thumbs up signThey are talking about some plumber's tool which is quite stiff, Bob. Maybe your tool is too rubbery limp to get the job done? :-)
A. Bought a this on eBay or Amazon [affil links] titanium watch earlier this year, pleased with the watch apart from the grey scratches it leaves on the sink. Bought a porcelain rubber from a local branch of a nationwide plumbers merchants which did the trick very easily. Cost between £12-£15 as I priced them at three different suppliers. Tried the net but had no luck
Michael Perkins
- Portsmouth, England
November 29, 2008
thumbs up signHaving just moved in to a brand new house 4 weeks ago I was dismayed at the small black marks appearing on the sinks ~ usually after I'd cleaned them. Having read the comments on this site I am now shocked to realise it is my wedding ring causing the damage. I chose titanium as an alternative to any other metal as it is stronger and less reactive. I have now resorted to an alternative and have lots more cleaning in front of me. Thank you for all your advice: I'm now off to purchase a china/bath/plumbers/crammer rubber!
Rachel Richards
- Bedfordshire, England
July 30, 2010
A. 600 grit wet/dry sandpaper works wonders (wet the paper and use some elbow grease); I also tried automotive rubbing compound this on eBay or Amazon [affil links] , messier but also good.
Tony V [last name deleted for privacy by Editor]
- Sibey, B.C., Canada
A. Regarding metal scratches on porcelain, I have successfully used rubbing compound this on eBay or Amazon [affil links] (used to rub out minor scratches in car paint).
Tally R [last name deleted for privacy by Editor]
- Winnipeg, Manitoba, Canada
A. I had a blocked toilet and used a snake to fix it - this worked a treat, but left REALLY bad dark grey scratches on the porcelain.
I drained the toilet completely (scooping out the water with the lid of a deodorant spray and mopping up the rest with toilet tissue :)
Once dry, I used T-Cut "Original colour restorer" available from car cleaning product stores and one of those nylon pot and pan scouring pads. Scrubbed away for 10 mins and now it's as good as new!
Steve Bird
- Scotland
Toilet Auger
toilet_auger
A. Use a toilet auger this on eBay or Amazon [affil links] rather than a regular snake next time, Steve, and avoid the damage. I know, I know, we Americans don't know what a bath rubber is and you British/Scottish don't know what we mean by toilet auger :-)
. . . but it's a short plumbing snake with a protective rubber sheath so you don't scratch the bowl.
A. Have tried all sorts of cleaners to get rid of marks caused by my husband's titanium ring on the bathroom sinks, but no luck! Read a post mentioning T-Cut and it worked magnificently, thanks!
Linda Kay
- Durham, England
April 20, 2010
Cerama Bryte
cerama_bryte
A. My husband and I discovered today that Cerama Bryte glass cook top cleaner ⇨
does an awesome job at removing the black/grey marks left by our steel pots and pans and his titanium wedding band!
Jennifer C [last name deleted for privacy by Editor]
Homemaker - Middletown, Rhode Island
thumbs up signOH MY GOSH! That stove top cleaner for glass stoves really works! I used the Sear's brand because that is what I had, along with the little soft scrub sponge used for the glass stoves - not much elbow grease - and the scratches are GONE! THANK_YOU!
Linda S [last name deleted for privacy by Editor]
- Hemet, California
thumbs up signWhoever first recommended the glass stovetop cleaner as a solution- IT WORKS! I have tried so many things and read this over the weekend- took less than 5 min and a little elbow grease to get them out- used a scotch brite no scratch sponge (has a course dark blue side you can scrub with), in addition to the stovetop cleaner- This works! Thank you for the idea...
Brian Thomas
Tampa, Florida
January 28, 2008
A. Like someone mentioned above, I made a mess of a clogged toilet by using a toilet auger this on eBay or Amazon [affil links] & drain snake to open the clogged toilet. The marks it left appeared to be permanent; I tried removing them with toilet bowl cleaner this on eBay or Amazon [affil links] , a cleaner wax and even tried WD-40 this on eBay or Amazon [affil links] . None of them helped at all.
While at Home Depot I found the product Cerama Bryte. I also priced new toilets while there because I was certain the marks I created could not be removed.
With very little effort the marks were completely removed and the toilet looks as new. I recommend Cerama Bryte this on eBay or Amazon [affil links] to everyone.
Joey Yates
- Panama City, Florida
December 30, 2008
thumbs up signI also had horrible scratches on my bowl from a metal auger; I used the cooktop cleaner as well and I couldn't believe my eyes. It was incredible. Before that I thought I'd have to either live with it or buy a new toilet! Thanks for this website and blog -- much appreciated.
Sherry Ridenour
- Saint Louis, Missouri
January 3, 2009
thumbs up signI just read about the ceramic cooktop cleaner and tried it. Effortlessly cleaned the stains that have been there at least since we bought the house 18 months ago. Thanks so much. It is people helping people that really gets things done!
Justin Allen
- Fife, Washington, USA
January 16, 2011
A. I've used the cleaner sold for Pfaltzgraff dishes (www.pfaltzgraff.com) --just enter "cleaner" in the search box--I bought it at a department store) or the cleaner for Corningware dishes (also bought at a department store). Both worked beautifully for removing the black/gray scratches left by pots and pans.
Rebecca Bilek
- Saint John, Indiana
Q. I am looking for something to bring back the shine on my porcelain sink?
Debbie Bard
buyer - Palm Harbor, Florida
February 11, 2008
Q. Like a former poster, Debbie B. of Florida, I too, am looking for something to bring back the shine on my porcelain sink? Does this require a professional or can the homeowner successfully do this? What product to use?
Gini Nellis
- Milwaukee, Oregon, USA
November 3, 2010
A. Whew! My current solution is:
Gel-Gloss [affil links]. This product is in a spray can. It is a cleaner with a polisher. I purchased it for our acrylic faux marble sink vanity. I gave it a try on those tough to remove metal pot marks in a white porcelain sink. Nothing else seemed to work, including cook top cleaner and old fashion cleanser with bleach. I even tried the Mr. Clean eraser to no avail. It took several tries, but the marks are lightening and almost gone. The can information states that you can use this on fiberglass, marble, acrylic, ceramic, chrome, stainless steel, porcelain and plastic laminate surfaces.
It's gotta be better than sandpaper.....
fran funds
- Ormond Beach, Florida
February 17, 2008
A. I found it! Jewelers, Eagle One High Speed Green Rouge this on eBay or Amazon [affil links] cleans and polishes metal and it removed the black metal scratches from my white dishes. I immediately followed up with Soft Scrub to remove the residue and put the dishes through a complete cycle in the dishwasher.. I have been looking for something to clean my dishes for at least 10 years...
Sheri Marchese
- Myrtle Beach, South Carolina
May 18, 2008
A. My husband transported our sink in the back of his ute along with some metal posts that scratched it. We tried everything to get rid of them and after looking at this site I called a few plumbers but none of them had heard of plumbers rubber BUT one company's storemen recommended a product called Chemico. Its a pink paste and you can buy it for a few dollars in the supermarkets here in New Zealand. It completely erased all marks! I can't stop going in to stare at it :D
Nicole B [last name deleted for privacy by Editor]
- Richmond, Nelson, New Zealand
October 10, 2008
thumbs up sign"in the back end of his ute"?
My cousin Vinny told me that proper English is "near the end of his ute".
I only keep going in to stare at my toilet bowl after drinking too much, Nicole :-)
Cheers,
"Wright's Silver Cream"
wrights_silver_cream
A. My husband found that Wrights Silver Cream this on eBay or Amazon [affil links] took the pot marks off my sink.
Lois Kafferlin
- Meadville, Pennsylvania
January 2, 2009
A. Wrights Silver Cream this on eBay or Amazon [affil links] worked like a dream. Thanks so much!
Cindy Russell
flooring - Baker, Louisiana
February 19, 2009
A. Barkeepers Friend this on eBay or Amazon [affil links] is the best for the scratches in your sinks. C Davis
- Virginia Beach, Virginia
March 29, 2009
thumbs up signI had the same problem. Found this thread and went and bought Barkeepers Friend from Lakeland for £1.99 (GBP).
It worked like a treat after about 2 minutes of rubbing.
Bob Bobins
- Bath, UK
July 9, 2010
A. I had pots/pans scratches in my wife's Jacuzzi porcelain sink. Boy was she mad! Used Soft Scrub with bleach [affil links] with no luck. Then I remembered I had some Kit Scratch Out [affil links] in the garage for my cars. Worked like a miracle in the sink. Saved my life!
Rick Namm
- Albuquerque, New Mexico
April 24, 2009
Q. I have bought a "Pumice Stone"(which does not specify that it will scratch toilet bowl) to remove Calcium, Lime and black water ring deposit into some off my boss' bathroom toilet bowls in the house. The 2 white bowls came out clean after some soft rubbing and "elbow oil" ... then I did the same thing to our Black toilet bowl. Was fine when wet, but once it dried out, it showed white scratches all over the bowl. Does anyone know how to get rid of these scratches, as I'm about to lose my job or buy a new $1500 toilet bowl.
Frenchy Aspen
employee - Aspen, Colorado
July 5, 2009
A. Hi, Frenchy. Many people suggested Barkeepers Friend this on eBay or Amazon [affil links] ; that's probably your best bet. But if you reach desperation you might try a clear coat of Everbrite [a finishing.com supporting advertiser] -- it is said that if something looks good wet, it should look good with Everbrite on it.
A. I have tried everything to get the marks left behind in my porcelain sink and nothing worked. I finally tried some of my husband's Gojo this on eBay or Amazon [affil links] . It worked great! All of the marks are gone.
Misty Stevens
- Pryor, Oklahoma
A. A nasty dark scratch appeared on my less than 12 month old bathroom sink over the weekend. Funnily enough, my boyfriend was staying over and he was wearing a titanium ring (hmmmm....could this be the culprit of the aforementioned scratch?) I think it could well be after reading the previous posts.
I just had a scout around in the ol cleaning cupboard and tried Hob Brite - it worked a treat, so there's another one to add to the list :)
Helen Harvey
- Seend, Wiltshire, England
A. I also had those nasty black marks on my porcelain sink. went to the dollar store and purchased those rubber mat liners that you put underneath, so that you won't slide. cut off a piece and rub it on the marks....COMES RIGHT OFF IN SECONDS. :))))).
Joanna.
Joanna Russo
- Toronto,Canada
A. I noticed a dark scratch mark on my new porcelain sink. I don't know where it came from - yes, I do have a titanium watch, but I don't usually wear it when washing! Anyway, I tried 1200 grit wet/dry paper; came off in about 30 seconds with quite gentle rubbing.
John Connett
- Exeter, Devon, UK
October 26, 2009
A. I had the same snake/toilet marks as other posts. After reading this I tried scrubbing, bleach, Oxi clean, pumice, a cream multi metal cleaner, and Easy Off glass cooktop cleaner. Nothing worked.
Then I tried the Mr Clean and started to see results after quite a bit (8-10 minutes) of elbow grease. I then applied Wrights Silver Cream this on eBay or Amazon [affil links] with the Mr. Clean Magic Eraser pad this on eBay or Amazon [affil links] and miraculously the marks went away quite rapidly. Thanks for all the suggestions. This last combo definitely worked for me!
Lola Turner
- Boise, Idaho
A. We had this problem with my son's razor. After seeing the other replies I thought I need a paste that has abrasive particles in it. Answer toothpaste. A sheet of loo paper and a small blob of toothpaste was all it took. 2 minutes later it was perfect again.
Graham Tebbutt
- Sutton England
A. I was washing up some metal equipment for my D of E expedition and I ended up getting metal 'scratches' all over the basin of the sink.
Anyway, my mum went mental.
So I came on here... Toothpaste and kitchen roll you say?
Got every mark out within 5 minutes with some of the frequently aforementioned 'elbow grease'
Lifesavers!
Andrew B [last name deleted for privacy by Editor]
- UK
April 22, 2010
A. I scratched a new bathroom sink removing the label with a knife, foolish in hindsight.
Toothpaste and kitchen roll, fixed it in 2 minutes, magic :)
T Stevens
- UK
May 31, 2010
A. I scratched our bathroom sink earlier today and was really angry with myself as it always seems like when you are trying to fix one thing something else goes wrong! Well, I got mad and swore and felt terrible. Then I decided to do a search on the trusty internet where I found this forum on scratched sinks. Thank you to all for your suggestions. I read until I found a suggestion that included materials I had at home. Toothpaste and toilet paper, yes indeed, we have these! And it worked like a charm. Wouldn't have believed it but it is true! Only took a minute and the sink is as good as new. Definitely the easiest of solutions!
Christine Taylor
- White Rock, BC, Canada
June 7, 2010
Q. My wash basin had a lot of scratches from my husband's titanium watch strap. After trying all kinds of cleaning products without success, I found this invaluable thread of helpful information and tried the toothpaste (on kitchen towel) suggestion somewhere above and with about 10 minutes of elbow grease all scratches disappeared. Fantastic!
Now, a month later, more scratches are appearing from the same watch strap in the same place but this time the toothpaste will not shift even the lighter of the marks.
(Unfortunately, hubby consistently fails to remember to remove his watch, even with a reminder desperately stuck above the sink...)
Is it possible that the toothpaste originally took off the scratches AND the top surface of the china? The edge of the basin looked great after that first successful cleanup, but thats the only thing I can think of which would result in the same agent not removing further damage.
Will now try various other suggestions in this thread, probably starting with the Cramer Bath Rubber which I've just ordered and if that doesn't do it I'll get Cerama Bryte ceramic cooktop cleaner from eBay uk and have a go at that and will eventually come back with the results in case anyone else has a problem with further scratch removal.
Pam Yeates
- Bristol, UK
June 16, 2010
A. I have finished those by using of the toothpaste, just put it to the damaged surface and then rub as much as you can, I have remove 4 stains in few minutes but I have a blister on a thumb now... Anyway, cheapest and probably fastest solution...
igor dugonjic
- Sarajevo, Bosnia and Herzegovina
August 5, 2010
thumbs up signWell I'll be. Toothpaste and TP. Smells nice, too. Too enthusiastic with the toilet auger today, even they can mar porcelain. A poignant vote for my late grandmother's Pepsodent tooth powder. The tin.
Ann Landrey
- Toronto, Ontario, Canada
March 10, 2011
Toothpaste gets marks off plates. I use it often and its cheap too, put some toothpaste on the plate and clean it with a paper towel or a cloth. Works on other items too.
Lillian Harris
- Etobicoke, Ontario, Canada.
April 9, 2011
I was wondering how to get marks out from a ring or watch etc and I was thinking T-cut would do it, Nope.. But because I was a valeter I did not give up so I tried another polish....
G3 (yellow pot and blue background)
Worked perfectly and all are completely gone! Work it in and it will go, even using one finger and no cloth.
Darren Davies
- Andover, UK
This solution may or may not work with titanium, but it is magic for those who have marked up their toilet bowl with an auger. Get Jobmaster Bathroom and Bowl cleaner (usually from Costco) or any strong bathroom cleaner with phosphoric acid. The Jobmaster stuff is pink with a slight cherry syrup smell. Flush the toilet twice (to make sure you have no other chemicals in there), then pour about one to two cups of the Jobmaster in the bowl. Come back in a couple of hours and the bowl will be spotless, no scrubbing needed! I never thought it would work so well. It removed every scratch, even in the area where you wouldn't be able to scrub unless you had very tiny hands. I figure that the scratch marks is iron oxide from the auger. Most acids should be able to dissolve iron oxide, but phosphoric acid is especially good at it (remember Naval Jelly?)
John Smith
- San Diego, California
A. We too have a bore water supply to the toilet that leaves a mineral deposit in the bowl - the only effective way I have found to remove it is using a coarse sand mix and a damp cloth - form a pad with the cloth, dip it in the sand and use as a scourer on the pan - a bit physical, but it works and no chemicals involved.
Clive W Bulmer
- Adelaide South Australia
September 15, 2010
A. I just moved into a new home and found grey marks in my porcelain sink.
probably from oven racks.
i looked here and followed advice for the glass stove top cleaner .
i popped it into the search engine and low and behold there is a homemade version.
i did think initially "yeah this won't work" but to my surprise it did.
White vinegar in bulk on eBay or Amazon [affil links]
Baking soda
i just gently poured the vinegar onto stain, sprinkled some baking soda on and drizzled a bit more vinegar on for good measure. left it to bubble for 15 mins and then scrubbed it.
it works almost 100%, I'd say about 96%, but not bad for things already in the kitchen
Andie melvin-harris
- plumpton green,sussex,uk
Dremel Kits
dremel
I scratched my sink so bad with my titanium ring I thought it was cracked. You could actually feel the scratch with a fingernail. I got out my Dremel this on eBay or Amazon [affil links] , mounted a hardened cotton bullet tip to it..set it to the lowest speed. I used Meguiar's Fine Cut [affil links] polishing compound ... I had a 2" long black cut in the sink--it actually took less than a minute to completely remove it. If you have a dremel--then this is the way to go.
doug baehr
- Elma, New York USA
January 14, 2011
thumbs up sign After reading most of the advice to remove metal scratch marks from ceramic, I tried a ceramic hob cream "Hob Bright" with a soft sponge and plenty of elbow grease and all 8 marks are completely gone and sink is like new once more.....Thanks for the advice
Christopher Courtney
- Dublin Ireland
January 30, 2011
Q. Toothpaste and elbow grease worked great!! The black marks are mostly gone and sink looks very clean, however there are teeny tiny scratches in the finish ... any idea how to refinish those?
Liz Anderrson
- Falls Church, Virginia, USA
October 19, 2011
A. I have tried many of the mentioned "cures" but never really got my sink mark free. I looked for the Cramer Plumbers Rubber, but unless I ordered online, it's not available locally. I have a pumice stone and was afraid to us it on my enamel sink so... as I was making a shopping list I noticed my pumice stone for pedicures. It is a lot smoother and finer than any other. In about 2 minutes I had 8 years of marks gone! I am spreading the word, it worked wonderfully! The easiest and cheapest "cure" yet!
Brandi Johnson
- Clovis, New Mexico, USA
November 19, 2011
MAAS metal polish
maas_metal_polish
After reading all responses, I thought I would try using my MAAS Fine Polishing Creme for all metals first before trying the Cerama Bryte this on eBay or Amazon [affil links] or Weiman Cooktop Cleaner this on eBay or Amazon [affil links] or the Plumbers (cramer bath) rubber. The rubbers were harder to get here (no pun intended).
Well on the back of the MAAS polishing creme it says it restores glass, plexiglass, fiberglass, enamel.....removes rust and oxidation. that was very similar to the products mentioned.
Sure enough with a sponge, a few minutes and "elbow grease" it worked like a dream! Thank You for steering me in the right direction!
The Maas polishing creme is also easier to find in the US than the cramer's bath rubber. Although I wonder if the "all-purpose polishing buffing compound bars" on eBay are the same thing, or would accomplish the same/similar thing?
Brandon Kelley
- Rochester, New York, United States
February 6, 2012
Mothers Polish
mothers_polish
A. My titanium ring also made black marks on my brand-new white porcelain sinks as I was installing them! I didn't realize how it happened at first, but tested it out and made another black mark which confirmed it (that was dumb of me). The magic eraser did not work for me, nor did regular soft scrub (I didn't have the kind with bleach), but your suggestions got me thinking. A quick browse in the garage turned up a bottle of Mothers chrome polish , which did the trick. It only took a minute or two of rubbing with a paper towel and each mark went away. When I was done, I polished my ring up a bit :)
Adam Giuliano
- Richmond, Rhode Island, USA
A. I also had a blocked toilet and used a snake - and it left bad dark grey scratches on the porcelain. I paid $1.85 for Barkeepers Friend . With little effort the marks disappeared.
I thought I was going to have to replace the toilet. Thanks for the suggestions!
Marky Mark
- Charlotte, North Carolina
A. Cramer Bath Rubbers are available on eBay
Sid Conway
- Birmingham, West Midlands, UK
A. I am a plumber, and this sort of thing happens all the time, I always carry a tube of cutting compound on my van, you can get it from any motor body or parts shop. Works a treat and doesn't damage the surface.
Simon davies
Ad plumbing, gas & electrical - Manchester, England
Q. My sink has tiny scratches on it and some of them rust. I tried the Barkeeper's Friend and it took away the rust, but it left the surface rough. I guess it took off the finish. I don't know if I didn't get it wet enough before scrubbing or what. Is there any way to make the finish smooth again?
Sharron Mize
- Tupelo, Mississippi, USA
June 2, 2012
A. Hi Sharron.
This thread has gotten long and ragged, so it's not clear whether you are still talking about a porcelain enamel sink or what :-)
I'm surprised that Barkeeper's Friend, even when not wet enough, is gritty enough to seriously roughen a porcelain enamel surface, but a buffing pad on a cordless drill, with a wet and very mild abrasive, should be able to polish it. Acrylic and fiberglass sinks, if that's what you have, look nice but the finish is actually soft and not very durable ... on the other hand, I don't see how they could have rusted. On the fourth hand, maybe you're talking about a stainless steel sink?
thumbs up signIn response to Jennifer C's post
The ceramic stove top cleaner worked like a charm to remove metal stains from my sink. I had several that had been there for a few years, It took some elbow grease but they all came off. Thanks for the post.
Pam Davis
- Jacksonville, Florida USA
September 20, 2014
A. Hi all!
I appreciate all of the suggestions above. As titanium replaces gold as a jewelry metal, I'm sure many will benefit from this information.
Unfortunately, plumber's eraser is not available in Canada, and I tried Ceramabrite, Soft Scrub and the various other suggestions with either no luck, or an overabundance of elbow grease required. I also tried my Dremel tool with a felt tip and polishing compound - no joy.
To those who suggested 600 grit sandpaper, THANK YOU! Purchase a package of waterproof 600 grit sandpaper. Cut small pieces, 5cm x 5cm. The ceramic finish is harder than the grit, so it doesn't last long - be prepared to use 2-3 pieces if the stains are extensive.
Sand wet, just using the pressure of your thumb against the stain, and presto. I just cleaned a year's worth of scratches from 2 bathroom sinks and a bunch of ceramic kitchen cupboard handles in under 15 minutes. I used about 1/3 of a sheet to do all of this.
David Caird
- New Westminster, BC, Canada
September 7, 2015
thumbs up signThanks all for the Cerama Bryte this on eBay or Amazon [affil links] tip!! It worked perfectly!! :D so happy!!
Sarah Feinsmith
- Queens, New York
December 29, 2015
A. The best way I have found to remove black marks from white porcelain, is to use "Mica Ceramic Cooktop Cleaner".This is the type you would use on a flat glass halogen cooktop, or glass induction cooktop. Just use a small amount of the liquid cleaner on paper tissue, on the marks. With a bit of rubbing in the direction of the scratch, they are gone in under a minute! AMAZING!
(These "Ceramic cooktop cleaner" products state they are non-abrasive, but they actually contain finely ground mineral called mica, which is very slightly abrasive.They only to act as a polish, which is why you can get your cooktop shinier with this stuff than anything else. (and your bathroom porcelain, if you are really particular!))
Gerry Williams
- Christchurch, New Zealand
February 2, 2016
A. Try citric acid this on eBay or Amazon [affil links] . I successfully got rid of metal scratches on porcelain tiles. Just apply acid and scrub with normal scrubber.
Sweety Mathur
- Delhi, India
April 21, 2016
A. Mr. Clean magic eraser this on eBay or Amazon [affil links] with Barkeepers Friend and lots of elbow grease will get most of the titanium marks off. For me it took a whole "eraser" and probably 3 tablespoons of the "Friend"
Butch Johnson
- Belen, New Mexico, USA
April 30, 2016
A. I have just tried Turtlewax color magic polish [affil links] shades of white and it worked!
Kathryn Martin
- dumfries scotland
August 1, 2016
A. You can use a product called Tcut, it's used in the automotive trade for finishing and removing scratches from paint.
I used it with a polishing pad on a cordless drill,removed all black marks and gave a super finish.
Andy wyatt
- Bristol- Avon england
September 25, 2016
A. I used Menzerna Heavy cut polishing compound 1000 grit and the marks came off with 15-20 seconds of heavy rubbing. It took off the new titanium marks that I put on and several old marks of unknown origin.
Rocky Ballew
- Houston, Texas USA
May 22, 2017
