No passwords, No popups, No cost, No AI:
we earn from 'affiliate link' purchases, making the site possible
Sound technical content, curated with aloha by
Pine Beach, NJ
  for Metal Finishing 1989-2024
Pre treatment for plastics
I face problem of adhesion to metallized reflectors in ABS,PC. The reflectors are directly metallized after molding without any pretreatment or base coat.In peel off test the reflector fails in some areas only. I would like to know what is plasma treatment and how is it done?
Mahendra
- Nashik, Maha, INDIA
Plasma discharge is a process whereby a plasma is struck in a low vacuum. The vacuum is typically less than 250mT. The most useful gases for ABS and PC are oxygen, nitrous oxide or air. Suitable powers for polymer activation are in the order of 80-120W and processing times between 1 and 5 minutes, depending on the polymer.
