GME 60-206-E Requirements
Hi!
I am working as a Lab Manager in an important Seat Belt company. One of my components drawings says "Salt Spray Fog Test To GME 60-206-E Grade 2".
What do you know about this requirement and for how many hours do I need to have this component exposed to salt spray?
Juan C. Crispin
- Del Rio, Texas
Juan - This standard is now GMI60206 and can be obtained from Global Engineering. It will tell you the salt spray requirements and performance criteria.
Cynthia L. Meade
- Sylvania, Ohio, USA
Juan, according to your question: "Salt Spray Fog Test To GME 60-206-E Grade 2".
GMI 60 206 - TEST PROCEDURE.
Determination of Resistance to Corrosion of Automotive Components by Salt Spray Fog Testing (SST).
"E" - TEST CODE - SST 72 hours
"Grade 2" - after SST corrosion of coating allowed but no corrosion of the base material.
Best regards,
DOROTA PIWOWARCZYK-ZIMNY
DELPHI - KRAKOW, POLAND
I need an Information about this standard GMI60 206 K - how many hours in SST, Ni % and coating layer thickness? Can you help me or send me the norm?
JÊDRZEJ GORCZYÑSKI
Surface treatment and coating - Wroclaw, Poland
