Restoration of 304-3 Brushed Surface S.S.
We manufacture electrical distribution equipment such as Sub-Stations, Metering Devices and other related products. During the past 2 years we have been processing stainless steel 304-3 which has a brushed surface and is delivered with a Teflon type film to protect one side of the 4' x 10' sheets. My question is, what equipment is readily available in the market that could restore the uniform pattern after parts have been either spot welded or welded with the use of Mig-Welders. I assume that one would need an apparatus that will ensure a straight and constant rate of pressure and speed in order to obtain or restore its factory finish.
Thank You,
Jesus M. Alicano
- Canovanas, Puerto Rico, USA
Wide Belt Sander
If your parts were complete flat or flush, you might be able to use a wide belt sanding machine like Timesaver; however, the visuals you provided appear to have hinges and latches which may better be finished by hand with a non-woven wheel system. If you have a lot of volume, there are people or companies that build special machines systems.
tony kenton
AF Kenton
