Copper strike problems
We are plating copper over steel sheet. Being in a third world country we are mixing our own strike solution consisting of:
Potassium Cyanide (NaCN)
copper sulphate this on eBay or Amazon [affil links] (CuSO4)
When plating large pieces of sheet metal, we experience bubbles and bumps on the surface.
Is there an anti foaming or other agent that can be made from common chemicals that will control this problem?
Totok Priharsanto
- Yogyakarta, Indonesia
Totok,
Parts are blistering from your copper strike, may be lot of the reasons, Check the part after soak and electroclean if any grease left over the part, I do not know why are you using copper sulphate chemical instead of copper cyanide? Check metal in your bath, may be too high? or drag out oil or grease in your copper strike bath during the plating process. Some non cyanide copper strike bath are available , they are using copper sulphate and other chemicals.
popat patel
Popatbhai B. Patel
I'm a chemist. I want from you how to prepare copper strike in my laboratory -- what elements do I want?
Ahmed rashed
- mansoura, Egypt
May 24, 2010
Hi, Ahmed. You may realize this, but maybe you don't if you are not from the electroplating industry. In the developed world, plating shops very rarely formulate their own plating or strike baths anymore; rather they purchase them from companies who formulate them to proprietary formulas.
These proprietary formulas can be based either on sodium cyanide or on copper pyrophosphate. EPI / Electrochemical Products Inc. [a finishing.com supporting advertiser] is one source of pyrophosphate strike baths.
The Metal Finishing Guidebook and the Electroplating Engineering Handbook this on eBay, AbeBooks, or Amazon [affil links] are good sources for formulas but -- because of the increasing tendency for shops not to formulate their own baths -- older versions of these books will be more informative on home-brew than newer editions. Good luck.
June 27, 2010
