Uses of Argon gas
Q. Why only argon gas is used in optical emission spectrometer? Kindly reply to this question.
Himanshu Mehta
Birla Copper - Bharuch, Guj, India
A. It's probably something to do with: In spectroscopic analysis it has some properties that are similar to Helium or Hydrogen. Look up optical emission spectroscopy abstracts --
Argon is inert, cheap, readily available.
Argon based spectrum analysis tools for the metallographic analysis are already available by some pioneer industries like Leco.
Randhir Birdi
- Montreal, Que., canada
A. Following are the reason why Argon Gas used in Optical emission Spectrometry.
1.Argon gas is inert in nature. When it is flushed in Sparking area, air gets removed. Sparking gets improved due to non-existence of air.
2. Molecules of Argon gas are bigger which also improves sparking.
3. Argon is easily available and cheap.
Best Regards
Vikram Mulay
- Mumbai, India
Q. Which impurities in argon for spectrometer is important?
What makes a spark white?
mahdieh arjaneh
- tehran, iran
November 14, 2015
wikipedia
Inductively coupled plasma mass spectrometry
Q. What is the principle of argon spectrometer?
onkar Sharma
- Pune, Maharatra, INDIA
January 8, 2016
January 8, 2016
Onkar,
Argon is a gas, not a type of spectroscopy. I imagine you are referring to optical emission spectroscopy, which USES argon gas, as referred to above.
I'm not sure what your current level of knowledge is here. If you are well versed in physics you should get the idea quickly from this and the related articles:
https://en.wikipedia.org/wiki/Spectral_line
If you are not well versed in physics then something written more for a layman audience is
http://www.irregularwebcomic.net/3259.html
For how the OES puts this into play, see
http://www.shimadzu.com/an/elemental/oes/oes.html
ray kremer
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
