COATING ON WELDED AREAS
WE WANT TO KNOW THE SOLUTION, HOW TO GET ADHESION OF THE PAINT OR POWDER COATING ON WELDED AREAS ( ARC / C02 / SPOT WELD AREAS).
ABHIJIT.S.BAPATTATA ENGG - INDIA
Dear Mr.Abhijit,
If it is mild steel, you can use 3-in-1 solution to get better paint binding.
Ramchander- Hyderabad, India
Dear sir:
You have not mentioned what system you are using for P/T. You can get try some new surface conditioner before phosphating for better results.
Anurag Kanaujia- New Delhi, India
