Cleaning and Passivation of Stainless Steel
A friend has welded some couplings on my stainless steel boiling pots for me. The industry uses nitric acid to clean & passivate stainless after welding, etc. How can I do this at home? I have read about nitric acid & it seems to be some bad stuff. Is there an acid solution for the "home market" that I can buy that will clean & passivate stainless?
Robert W. Kolacny- Wharton, Texas
Yes, you can get very good passivation of welds using safe citric acid products. There are gelled products like paint or even trigger sprayer products. These products will do a good job of passivation, but will not remove all of the weld discoloration, if you need this. You can easily remove that in a number of ways before passivation. Call us if we can help.
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
