Acid and Metal Reactions
Q. When an acid is added to a metal, what kind of reaction is produced?
Beth R [last name deleted for privacy by Editor]- Cordele, Georgia
by Steve Spangler
A. Some acids react with some metals and not all acids react with all metals. It all depends on what is reacting with what. However, assuming there is a reaction, the acid will dissolve the metal to produce the metal salt of that acid; at the same time it will produce hydrogen gas. i.e., 2H+ + M = 2M+ + H2
However, there are some exceptions; if you mix conc. nitric acid with copper, you will get clouds of brown nitrogen dioxide gas.
A. Thanks, Trevor.
As you know, there is a reason for that special reaction between nitric acid and copper, but it doesn't exactly have to do with metals and acids. HNO3 doesn't just ionize into H+ as a cation and NO3- as a stable anionic radical per your equation, like other acids -- rather, the NO3 acts as a very powerful oxidizing agent.
Although we call it nitric acid, it probably could have been called "nitric oxidizing agent" :-)
A. It would be a chemical reaction.
Mellisa Lynhart- Karratha, WA, Australia
A. When acids and metals react, a salt and hydrogen is produced
Martin Hawes- Manchester, U.K
September 29, 2009
Q. What do you get when you react a metal oxide with oxygen
bradley d [last name deleted for privacy by Editor]school - Belgium
October 16, 2009
A. Hi, Bradley. I'd say that most of the time nothing would happen because the metal has already reacted with oxygen to form a metal oxide and the reaction is done. Sort of like what happens when you burn ashes: nothing, the reaction is done.
But there could be some metal oxides like Cu2O that might be further oxidized to CuO.
October 16, 2009
July 8, 2011
"Hi, Bradley. I'd say that most of the time nothing would happen because the metal has already reacted with oxygen to form a metal oxide and the reaction is done. Sort of like what happens when you burn ashes: nothing, the reaction is done."
A. With all due respect, this is untrue. The reaction will proceed, but no gas will be evolved. Instead of a salt and hydrogen being produced, you will get salt and water.
The hydrogen from the acid will react with the oxygen from the oxide to form the water.
Ceri E [last name deleted for privacy by Editor]- Swansea, Wales, UK
Hi, Ceri. Thanks. But ...
Although the title of the thread talks about acid reactions, and you are right that when an acid reacts with a metal oxide you will get a salt and water, Bradley asked about reacting a metal oxide with oxygen, not with acid. And that's the question I answered :-)
June 2011
Q. We used an aluminium foil and hydrochloric acid reaction to produce hydrogen gas and blow up a balloon, which we then exploded; it caused a nice BIG fireball.
I was wondering if you could possibly explain the reaction the took place between the aluminium foil and hydrochloric acid?
student - Australia
December 2, 2009
December 2009
A. Hi, Kala.
Aluminum plus hydrochloric acid reacts to produce aluminum chloride and hydrogen gas. The general idea, in formula, would be along the lines of:
Al + HCl => AlCl3 + H2^
But there is a problem with this "formula", in that it doesn't balance because there is not the same number of atoms of the three elements on each side of the equation. You need to have three HCl's on the left to provide the 3 Cl's in the AlCl3 on the right:
Al + 3HCl => AlCl3 + 1.5H2^
But there is still a problem because there is no such thing as one and a half molecules of hydrogen gas. So the actual formula is:
2Al + 6HCl => 2AlCl3 + 3H2^
Q. Respected Sir ,
I would like to get an answer my question. I am a student of class 10. How do you come to know that hydrogen gas is produced .Show an experiment to prove that hydrogen gas is evolved. I need a solution to this urgently.
I hope you would not neglect such a question.
Thanking You
Yours Sincerely
Rekha
student - India
April 14, 2010
A. Hi, Rekha. Your question is not so much a question in the sense of "you know the answer or you don't", as an assignment for the student to think about. It seems to me that if we claim that hydrogen gas is produced, we should:
First, see if any gas was produced. What did your experiment reveal? Did it or did it not generate gas?
Second, capture that gas in a bottle. This could be done by sinking the bottle into the water and removing any air, then positioning the bottle to capture the rising gasses.
Third, test if the gas that was captured is hydrogen. This you would do by comparing some of the properties of the captured gas to the properties of hydrogen. Good luck.
April , 2010
A. The test for hydrogen gas is to put a lit splint into the bottle filled with gas captured from the experiment. If you see a small pop around the lit area of the splint, or hear a 'squeaky pop' sound, then the gas is probably hydrogen.
Poppy S [last name deleted for privacy by Editor]- Wiltshire, United Kingdom
March 22, 2011
Q. With due respect;
I'd like to get an experiment using hydrochloric acid across G.I pipe. How long this pipe will stand alone without any damage. If there is a damage what kind of reaction/theory has been occurs and how to prevent it?
Student - Manila, Philippines
May 9, 2011
A. Hi, Romel.
G.I. means galvanized iron (more likely to actually be galvanized steel). Galvanized means coated with zinc.
The zinc will almost instantly dissolve in hydrochloric acid.
"The reaction will proceed, but no gas will be evolved. Instead of a salt and hydrogen being produced, you will get salt and water.
Ceri E
- Swansea, Wales, UK"
Q. Interesting. Exactly what happened in my car. Some battery acid spilled inside my car during transport. A week later noticed the salt on exposed metal and water had collected between the base metal of the car floor and the sealed carpet. I dabbed the water dry but wonder what else might be going on. Will the salt and water produced go on to corrode the metal over time? or is the reaction complete and finished. The salt I'm looking at seems to be permanent (cannot be wiped off).Is there a base I should use to stop further damage? Thank you.
- Calgary, Alberta, Canada
September 4, 2011
A. Hi, Joan. You should probably sprinkle baking soda [in bulk on eBay or Amazon [affil links] (a lot of it) there to neutralize the acid remnants. Dabbing it up, you didn't get it all.
September 6, 2011
Q. Can you tell me seven metals that react with an acid to give salt and hydrogen.
The question is related to my 12 year old son's science homework.
- London, England, UK
February 21, 2012
A. Hi Malachy. Let me ask you a question first: How much is 351 plus 426? I am confident that you can do this in your head, and equally confident that no teacher ever presented that particular pair of numbers to you. The point is that you learned "extensible" lessons in arithmetic class, like adding the ones column, the tens column, and the hundreds column, rather than learning the sums of pairs of large numbers by rote.
Although the question you have asked seems a bit advanced for a 12 year old, I'm confident that the point is not for him to simply memorize a meaningless list of 7 metals by rote, but to learn something "extensible" about chemistry, like the general idea of rows and columns of "The Periodic Table". Thus I suggest that he google that term and, combining it with what he can read on this page, i.e., that aluminum and zinc are two of those metals, he should be able to make some excellent guesses towards 5 more metals, and then look up the metals he guesses at to confirm the reaction. Best of luck!
February 21, 2012
Q. Hi ... I am NAVEEN ... I need answer for a such difficult question. When an acid react with metal to form metal salt. Is there any solution to avoid the metal salt formation... One thing happened in my lab sulfuric acid reacted with painted metal, the metal salt formed. So kindly request you to tell the solution to avoid salt formation. Don't ignore this question.
Naveen Kumar- Chennai, Tamil Nadu, INDIA
February 22, 2012
A. Hi, Naveen.
Your question unfortunately entangles issues of practicality, theory, and semantics :-)
Semantically, there is no possible way to avoid formation of metal salts, because we are talking "definitions", and the reaction product of metals and acids metallic salts is "defined" as hydrogen plus metallic salts. But speaking in terms of theory, these salts do not necessarily precipitate, they may remain in solution depending on their solubility limit at a given temperature. In practical terms, you can certainly filter out any non-soluble metal salts and the remnants of the reaction between paint and acid. Good luck.
March 7, 2012
A. Another 'solution' would be for Naveen to make all of his / her labware and lab furniture out of acid-resistant plastics! No metal salts there!
(Sorry, I couldn't resist...)
Lee Gearhart
Q. When acids react with carbonates, what specific ionic compounds do they produce?
Naay Owus- Toronto, Ontario, Canada
March 7, 2012
March 7, 2012
A. Hi, Naay. Are you asking what would happen if you combined an acid like HCl with a carbonate like CaCO3?
_H+Cl- + _Ca++CO3- - => ?
Balance the equation and write your guess, and then we can go on ...
Q. I am 12 years old and am achieving a level 7 (I should only be achieving a level 5) and need the answer to answer the question my science teacher gave me! Tell me how we use metals and acids as a reaction in the real world?
Please help; many thanks.
- England
March 13, 2012
A. Hi. One example is that metals are dissolved in acids so that we can electroplate them; for example to make relatively inexpensive jewelry out of copper, but coated with gold. Acids are also used to remove rust from steel and tarnish from other metals. Wet a cloth with vinegar ⇦in bulk on eBay or Amazon [affil links] (an acid), shake a little salt on it, and rub the tarnish off a brown penny with it.
March 14, 2012
April 2, 2012
Q. Dear sir, why does hydrogen ion not easily discharge as compared to sodium ion in Castner Kellner cell, while in normal cells hydrogen ion discharges at cathode more easily than hydrogen ion?
Mohsin Baig- Sindh, Pakistan
Q. What would you observe when barium chloride solution is added to dilute sulfuric acid?
Megan Koh- Singapore
August 21, 2012
A. Hi Megan. Please put this into context. Otherwise, people might assume that you simply posted your homework assignment on the internet for someone else to do :-)
But start by considering what reactions might occur with these reagents, and what observable properties the products of the reaction might have. Good luck.
August 22, 2012
Thanks for the advice. Anyway I've found the answer. A white precipitate, Barium sulphate, BaSO4, will be formed.
August 25, 2012
August 27, 2012
Congratulations, Megan!
As a "BTW" which you might want to add to your report, to do chrome electroplating the plating shops need to use a mixture of almost precisely one part sulfuric acid per 100 parts of chromic acid. For reasons that almost nobody really understands, too little sulphate and you cannot plate chrome from it; too much sulphate and you cannot plate chrome from it either.
Guess what electroplating shops do to their chrome plating tanks if they have too much sulphate? They add barium to precipitate the excess sulphate per this poem .
Q. Hello!
I'm a Grade 8 Student And I would like to know what difference would I see if zinc is put in to hydrochloric acid and when sulfur is put in to hydrochloric acid?
- Canada
September 15, 2012
A. Dear Zoey,
sulfur (only S atoms) is a non-polar solid that does not react with acids, at least at room temperature (with nitric acid you may get a reaction heating, but I don't think that you could with hydrochloric). So, you may get some sulfur and hydrochloric acid as products (no change).
Zinc (Zn atoms in a crystalline metal matrix) is a metal that DOES react with acids eagerly... You may get hydrogen and zinc ions (Zn++) as byproducts in this reaction:
2 HCl + Zn --> H2 + Zn++ + 2 Cl-
Hope I answered your question! Best regards,
- Cañuelas, Buenos Aires, Argentina
September 19, 2012
A. Hi Zoey,
Probably too late for you to use, but the first thing you should do is write the left hand side of the chemical equations:
e.g. Zn + HCl -> ?
S + HCl -> ?
Now if you can work out what goes on the right hand side of the equation and balance up all your atoms it should give you an idea whether you will witness anything happening or whether it will just sit there and not react at all. Best of luck.
September 20, 2012
Hi my name is Bianca and I am a little flummoxed as to where to start on my 15 year old nephew's science project. We need all the help we can get because it is detrimental for his school certificate. It's about testing a factor that may affect the reaction rate of a metal/acid reaction. Which would be easier to choose and how do I begin?
1. Concentrate of the acid: more concentrated acids increase the reaction rate.
2. Surface area of the metal: a larger surface area increases reaction rate.
3. The type of acid: more active acids increase the reaction rate.
4. The type of metal: more active metals increase the reaction rate.
PLEASE HELP.
- Sydney, NSW, Australia
June 5, 2014
