Ammonium nitrate bluing
Year ago I blued guns with a solution of water, Ammonium nitrate and lye. I still have a number of these guns after 30 year and the finish is still good. I now want to blue a number of guns, but I have forgotten the formula. I am aware of the dangers of using this type of hot bath and am equipped to handle these problems. Could you please provide me with the formula utilizing Ammonium nitrate or possibly sodium nitrate this on Amazon [affil link] .
Donald E. Crafton
Crafton Repair - Espanola, NM
5 pounds lye
2 1/2 pounds ammonium nitrate
per gallon of water
working temperature 285-295 degrees, soak 15-40 minutes depending on the hardness of the steel.
Unbelievably durable black finish that can take a wire brush test without damage.
Have lots of ventilation when adding the ammonium nitrate as there are a lot of ammonia this on eBay or Amazon [affil links] fumes.
Will eat solder or lead.
Similar to what was used by the Germans on WWI weapons.
Robert Kraft
- Lusk, WY, USA
December 1, 2008
Thank you, Robert. Readers should note that the internet is a gigantic one-room schoolhouse, and it is not even remotely safe for the average untrained reader to consider hot blackening. This is for trained personnel with specialized facilities and proper personal protection equipment.
