Rust on chrome spoke wheels
I have some rust on my Chrome spoke wheels. I want to remove it the easiest way possible without damaging the underneath, What would be the best thing to use?.
Chris Thompson
- Beaumont, Texas
I've had good luck with products containing oxalic acid this on eBay or Amazon [affil links] such as a home cleanser called Barkeepers Friend this on eBay or Amazon [affil links] . Works fine on my motorcycle.
Tom Gallant
- Torrance, California
There are products with the acid base (Nevr-Dull this on eBay or Amazon [affil links] , "The Must for Rust" from Krud Kutter [affil links]) and another way is to use aluminum foil (wadded up). I have had good results with the acid on the rust (half hour or so) followed with the aluminum foil.
Ken Ishoy
- Winder, Georgia
August 31, 2010
