Enquiries about Electroless Nickel Plating
I would like to know the mechanism of electroless plating of nickel on a substrate. Also, I would like to know why is electroless nickel is more corrosion resistant than electroplated nickel?
J. CHENG- Hong Kong
Very briefly, electroless nickel is a solution which contains a powerful reducing agent like sodium hypophosphite or sodium borohydride which is capable of reducing the dissolved nickel to nickel metal in the presence of a catalyst, and the catalyst is nickel. So the reaction starts, and the deposited nickel continues to catalyze it.
It is more corrosion resistant than electrolytic nickel for two reasons. Firstly, a nickel-phosphorous alloy "metallic glass" is deposited, not nickel metal. Secondly, the thickness distribution is much better so there are no "thin spots" to rust.
