Case depth in carburizing or nitriding
Q. Can you please inform me where can I find national or international standards online that talk about case depth in nitriding or carburizing?
George Bougioutakis- Leeds, UK
A. Here are some American standards of possible relevance. Links to ISO, British and MIL-S-12515C SURFACE HARDENING: FLAME AND INDUCTION (FOR FERROUS ALLOYS) [inactive]
MIL-STD-1878A CARBURIZING, GASEOUS ATMOSPHERE, PROCESS FOR [Canceled]
SAE-AMS2759/7
CARBURIZING AND HEAT TREATMENT OF CARBURIZING GRADE STEEL PARTS
ASTM A534 Standard Specification for Carburizing Steels for Anti-Friction Bearings
ASTM A255 Standard Test Method for Determining Hardenability of Steel
ASTM E1077
[withdrawn] Standard Test Methods for Estimating the Depth of Decarburization of Steel Specimens
ASTM G79
[withdrawn]
Standard Practice for Evaluation of Metals Exposed to Carburization Environments
ASTM A37 Recommended Practice for Carburizing and Heat-Treatment of Carburized Objects -withdrawn 1936
ASTM A355 Standard Specification for Steel Bars, Alloys, for Nitriding
Search ISO specifications at http://www.iso.ch/iso/en/ISOOnline.frontpage
British Standards (BS) at http://bsonline.techindex.co.uk
British DEF, DTD, NES standards at http://www.dstan.mod.uk/ and DIN standards at http://www2.din.de/?lang=en
I am not sure exactly what you are seeking. Case [depth] is typically considered as the portion of a ferrous alloy, extending inward from the surface, in which the hardness is greater than that of the core.* However, it is common to specify a minimum hardness at a given depth, and this can be achieved by various combinations of temperature, time, surface carbon activity, and initial alloy composition. Carburizing and nitriding occur by non-steady-state diffusion described by Fick's second law, with a concentration curve that decays from the surface into the bulk [Mathematical solution requires diffusion coefficients and the erf function, and is covered in metallurgy/ materials science courses]. To avoid extreme brittleness, an upper limit is sometimes placed upon the surface hardness.
*ASM Handbook, Volume 5, Surface Engineering, p. 948 (1994).
- Goleta, California
Replacement for MIL-STD-1878
Q. Hi all,
I have 2 questions:
1) Which standard replaces the MIL-STD-1878?
2) Can I use this standard for SAE 4340 steel?
Tomer.
- Israel
January 9, 2020
A. Tomer,
According to
https://quicksearch.dla.mil/qsDocDetails.aspx?ident_number=37183
there was no replacement named at the time the standard was cancelled. Though Ken Vlach's reply above suggests some alternatives.
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
