Suggest Appropriate Lubricant for Aluminium Machining
I want to know that which type of lubricant is best in ALUMINIUM cutting & turning which also give shine to metal.
Brijesh Vasoya- Gujarat, India
I think you need to explain the equipment and/or its speed and what cutting tools you using before a good answer can be given.
AF Kenton
We are using Castrol make Alusol B Oil for machining Aluminium components.
D.B.Prabhu Ram- India
