ACID ACTIVATION
IS 5-7% sulfurIC ACID RINSE REQUIRED AFTER WATTS NICKEL BATH AND ACID COPPER BATH . WE ARE UNDER IMPRESSION THAT BRIGHTENERS STICKING ON TO THE JOB DECOMPOSE IN THIS ACID AND SALTS WILL DISSOLVE IN THIS 5-7% sulfurIC ACID, COMMENTS IN THIS ISSUE (SUBJECT) IS APPRECIATED.
Panjala Mukesh
Panjala Mukesh
fashion jewelry mfgr.
Hyderabad, India
Panjala Mukesh,
I do not think you need 5-7 % sulfuric acid concentration after watts nickel bath. You need 4.5 to 5.0 ph for this rinse tank at sorter time rinse.
popat patel
Popatbhai B. Patel
Why should we have an acid rinse?
Panjala Mukesh
Panjala Mukesh
Hyderabad, India
