Plating slot car racer parts
Q. I race 1/64 scale slot cars as a hobby. In some classes we run custom wound armatures that cost between $35 and $60. The armature commutators (copper) wear with use. We can recut the comms a couple times, but then the remaining copper is too thin for a recut, and the expensive arm is junk. Is it possible to copper plate the commutator, building up around .005 - .010" of copper? And if so, will the plating be able to be cut on a lathe without chipping?
John Pileggi
- Holden, Massachusetts
"THE" brush plating book:
Electrochemical Metallizing
by Marv Rubinstein
electrochemical_metal
A. Hi John,
To answer your question theoretically, yes it is no real problem to plate copper to that thickness and get good adhesion. But to answer it practically, that's a pretty thick plating and replating might not cost less than a new commutator. If you are an avid hobbyist you could get a brush plating ⇦ huh? setup and perhaps replate thinner but more frequently.
Q. Thanks Ted. Replacing the comm with a new one is not really a viable option since successfully desoldering the wires from the existing comm is extremely difficult. Where could I obtain a brush plating setup? Thanks.
John Pileggi [returning]
A. I believe that Gold Touch [a finishing.com supporting advertiser] can supply what you need, or search google for 'brush plating equipment'.
Q. Ted,
These comms segments are only around 1/8" x 1/8" in size. Do they make brush plating systems small enough? I've seen the pen plating systems which might be more appropriate, but film build appears to be very light?
A. "Brush plater" / "pen plater" / "tampon plater" is just semantics, John. You can get a convenient size stylus and the plating solution from any supplier. Good luck!
Brush plating equipment, chemicals, and supplies from Gold Touch
gold touch banner
