Control Valve Stem with PTFE Coating
Control Valve Stem, Looking in to Reducing Fugitive Emissions from Control Valves. One problem is high friction between stem and packing. The Packing can be made from PFTE or Graphite. The friction wares out the packing and increase the leakage from the valve beyond acceptable limits.
What I would like to know is:
1.would a PTFE coating on a stem reduce the friction and increase the life of the packing?
2.how does PTFE against PTFE react?
3. does the stem need any special surface finishes to help the coating?
- Huddersfield, England
I am not a valve expert, but teflon on teflon is probably not a good bearing surface. Usually a hard material against a soft material is a better idea. If the stem is highly polished, and then plated with electroless nickel, it would probably run well against teflon packing.
Steve,
Believe it or not, but it would have been helpful to know the size of the valves, chemistry going through them ... and temperature.
Why? Because instead of labyrinth seals and a conventional stem, you can buy diaphragm valves which DON'T LEAK (as much?)and last much longer. These are mainly made in different plastics.
Try Plast-0-matics .
Food for thought, anyhow.
Freeman Newton [deceased]
