Food Grade Anodized Aluminum
I am designing a container that will be used to hold pharmaceutical pills, typically aspirin. I would like the material to be lighter and cheaper than stainless steel. I have made prototypes of 6061 aluminum with a sulfuric anodize Type II finish (clear). Is this suitable for contact with the aspirin? Should I use Type III hardcoat? Are there any standards (perhaps FDA) that I should review?
Steve Rose- Minneapolis, Minnesota
Steve,
I don't personally know of any such regulations but letters 10881 and 12047 both discussed FDA approval of anodize. If I recall correctly, aspirin mixed with water is fairly acidic -- you may want to consider the polymer coating used on soda cans (see letter 12170).
Jim GorsichCompton, California, USA
