Touching up Alodine1200
I have scratched some Aluminum parts treated with Alodine1200, How can I get the touch up to work. I cleaned the surface with acetone ⇦ this on eBay or Amazon [affil links] Warning! highly Flammable! then an alcohol. The touch up beads up and doesn't stay on the surface that needs touching up. Please help! in a bind.
Joel Lala- Sturbridge, Massachusetts
Put on rubber rubber gloves ⇦ this on eBay or Amazon [affil links] or grocery store latex. Using Q-tips ⇦ this on eBay or Amazon [affil links] or a cotton rag, wipe the "bare" area with a deoxidizing solution at 3 or 4 times regular tank strength. Squirt on some clear water to rinse. Now wipe with 3X or 4X normal concentration of chromate. Squirt again with clear water, Let cure 24 hours. Take two aspirin and call me in the morning.
