Aluminum plating solution
Q. Hi I am trying to electroplate aluminum metal into the pores of alumina. Can I get a ready-made aluminum plating solution?
Phaneendra Medida
Drexel University - Philadelphia ,PA,USA
A. Hi Phaneendra. Aluminum is too active a metal to electroplate in the conventional sense (out of an aqueous plating bath), so no such solutions are available.
Q. If you could please explain what you mean by aluminum being too active of a metal for conventional plating methods I would appreciate it.
Thank You
Bobby Lineberry
- Elizabeth City North Carolina USA
Metals range from very noble (wanting to come out of solution / stay out of solution / stay metallic), like gold and platinum, to very active (wanting to remain in solution, combined with other materials), like sodium.
When a highly active metal is dissolved in a water-based (aqueous) solution and you try to electroplate it out, all that will happen is the water will separate into hydrogen and oxygen (or hydroxide). You'll reduce hydrogen from H+ to H (actually H2, hydrogen gas) before you will be able to reduce Al++ to aluminum (metal).
It is possible to electroplate aluminum out of molten salts, and organic solutions in an oxygen-free environment, but that doesn't sound like an answer to Phaneedra's situation.
