Determination of the concentration of gold solution
Q. I am trying to source the gravimetric procedure for the analysis of gold of a plating bath. Do you know where I could find it? Thank you.
Maria Quintana
- Coventry [England]
July 13, 2021
"Gold Plating Technology"
by Reid & Goldie
-- hard to find & expensive; if you see a copy cheap, act fast!
goldie
AbeBooks
A. Hi Maria. Reid & Goldie has a 25-page chapter on Analysis, including gravimetric methods. Unfortunately, I can't tell you where you can source an affordable copy of this increasingly hard to find book :-(
But according to worldcat.org, the University of Birmingham, which they claim is 18 miles from Coventry, has a copy :-)
July 2021
thumbs up sign Thank you so much for your help Ted
Maria Quintana [returning]
July 14, 2021
A. Hi Maria
Nearer to you then Birmingham is PMD Chemicals, a major supplier of plating solutions who have their main office in Coventry.
Gravimetric gold is not quite as simple as the books suggest and it helps to see a demo. If you contact PMD and ask nicely you might be invited to the lab or even get a visit from their technical rep.
thumbs up sign Thank you, I will contact them :)
- Coventry
August 18, 2021
A. Hi,
There are approx. 8 to 9 methods of gold assay: volumetic, gravimetric, fire assay, by potassium iodide, XRF, and so many.
I suggest you put an ash-less filter paper in plating bath, burn it; you will get the residue, purify it again, and check the assay.
bhupesh mulik
refining consultant - Mumbai, India
August 28, 2021
Hello,
Q. I am trying to determine the concentration of a gold solution. I had prepared a colloid gold solution by reaction with HAuCl4 and a sodium citrate solution. I had filtered the solution through a 0.45-micrometer membrane filter. And I would like to know how determinate the concentration in gold of my solution. If anyone can help me!
Corinne Martineau
- Netherlands
A. Most people would use atomic absorption spectroscopy this on eBay or Amazon [affil links] .
James Totter
James Totter, CEF
- Tallahassee, Florida
XRF Coating Thickness Analyzer
x_ray_thickness
A. Corrine,
If you don't have access to an AA, there are a couple of other methods you could try. If your company uses an x-ray fluorescence spectroscope to measure thicknesses, you can install software in it which will quantitatively analyze gold ion in plating baths. It's a fairly simple procedure, but standardizing is tedious. Also, if you don't calibrate it on a regular basis, your results will be about as accurate as a scud missile.
Gravimetric analysis is another option. By reacting a 5 or 10 mL sample of your solution with sulfuric and nitric acids, with heat, followed by complete reduction using hydrogen peroxide, you can extract gold metal which may be weighed on an analytical balance. That procedure is widely known and available.
Best bet? James was right. Atomic Absorption.
randy fowler
Randall Fowler - Fowler Industrial Plating, LLC
Cleveland, Tennessee, USA
Q. Have our ore in anaq solution, chlorine and 6M HCl, orp 720-920, pH .5-1.5. Maintain below boiling until the complex or with basic SiO2 background. once we know we have concentrated solution we pour through a ionic selective collector called analogin. We then strip the analigs. I need a short inexpensive ionic test strip to know when the solution is loaded before pouring through the analigs. Can you help me?
Mark Bateman
- Magna, Utah, USA
Q. How to determine gold in gold plating solution?
Huong Pham
- Vietnam
April 21, 2012
A. By what ever means that is recommended by the mfgr. of the solution or the salts.
Barring that, get an analysis book and find a method that will work for your particular alloy (hopefully in your budget also). The best methods are expensive.
May 2, 2012
A. I used to do this: I had a piece of platinum clad titanium gauze, about 15 cm2. I'd take a bath sample, add a gram of sodium cyanide, dilute to a suitable volume, and make it the cathode in a little plating cell I made out of a cut down plastic bottle. I used a little piece of 12 mm stainless rod as the anode. Apply current for about 40 minutes, with stirring.
Weigh before and after.
dave wichern
Dave Wichern
this on eBay or Amazon [affil links] ?
Huong Pham [returning]
- Vietnam
May 8, 2012
May 9, 2012
A. Dilute 1.00 ml solution to 100 ml with distilled water.
Digest 10.00 ml of this solution (in a fume hood) with 5 ml aqua regia. Hydrogen cyanide will be evolved. Warm gently until all solids dissolve.
Transfer quantitatively to a 100 ml volumetric flask [100 mL flasks on eBay or Amazon [affil links] and dilute to volume. If your bath Au concentration was 5 g/l you'll get 5.00 mg/l in your sample prep. This ought to be within the linear working range for Au. You may have to dilute the sample prep. a little more.
Evaluate concentration by comparing to s standard curve made with distilled water and at least three Au standards.
dave wichern
Dave Wichern
